Old 03-12-2011, 02:01 AM   #62 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
The testing done in the previous examples showed changes in the CD of the vehicles so in these cases it had nothing to do with rolling resistance.
In these cases it mainly has to do with frontal area. In most road vehicles all four tires can be considered part of the frontal area. Generally, the front tires do not shield the rear ones. This kind of favouable shielding or flow control can be partly achieved with side skirts like on Basjoos civic. Without this kind of flow control, under car air flows slightly outward from the centre line of the car approaching the wheels at a yaw angle of about 15 degrees for the front wheels (sometimes much higher) and at a lesser angle at the rear.
There may be changes in the RR of the tires with changes in aspect ratio but in these cases it was not measured.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
nigelcut (04-16-2016)
