Old 03-13-2011, 01:37 PM   #622 (permalink)
DJ_SpaRky
@Bix:
You can built one of the transistor arrays instead, go to prj.perquin.com/obdii/ for more info on that. (sorry, can't post links or pics, post count is too low)
Also, if there is nothing connected to input, the LCD should show the "Car Alarm" screen, or "Init Failed" error. You might want to check the line that says "// 40 does not work with some LCD, or some misterious problem so try 0 if it does not work" Should be Line 787 or so. I had to change it to 0 to keep Kanji Characters from displaying instead of the * for the "Car Alarm" screen.
Code:
DiabolicJourney_SpaRky
