Old 03-14-2011, 10:39 AM   #2 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by njplanson View Post
1) In my car, does the engine power the alternator which then charges/powers the battery which then powers my 12V outlets (and 110 outlet), as well as the HVAC?
Exactly.
2) If so, during normal operation of the vehicle, would power from solar panels plugged into a 12V socket directly power my HVAC and other 12V outlets, thereby reducing the load/draw on the alternator and therefore the engine?
Yes, but the solar cells will only reduce the load on the alternator and therefore save fuel if their voltage is greater than the car's system voltage (roughly 13.5-14v with the engine running).
Also, glad to see that you recognize ("however slightly") the small potential power contribution of photovoltaics. (Not saying it's not worth pursuing.)
