Old 03-14-2011, 11:35 AM   #4 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
The safe voltage of the panel will depend on the current output. Most commercial 12v panels seem to output ~19v in full sun, at ideal angles, which is fine at low currents (also typical of the size of commercial panels that would fit in/on a car) since you're unlikely to raise the system voltage significantly when the vehicle is operating/drawing power.
For an idea of electrical demands of a small car (Pontiac Firefly / Geo Metro), see this thread: http://ecomodder.com/forum/showthrea...olts-8908.html
And you're probably aware that if your panel is connected (however indirectly) to the battery when the vehicle is off, you'll want a charge controller to prevent overcharging.
