Old 03-14-2011, 08:30 PM   #43 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Xringer View Post
But, some (Dumb) high current chargers will apply a lot of voltage to the battery,at the end of the charge.
It could be up around 15v or more.
The worse case scenario is connecting a dumb charger to a battery that has an open cell.
That's when the charger could put extra high voltage on the battery, and the electronics in your car.
The stuff that stays on all the time.
??? Generally the absolute max voltage limit for 12v electronics is rather high in the 18-24v area before anything actually becomes damaged. I have owned many many dumb chargers and none has ever been able to exceed
16v, even open terminal no load.
So, Unless you are running a strip of bailing wire out of a 220v wall socket to charge your 12v battery it is nearly impossible for you to get a battery that high. (I say nearly because I have seen some pretty amazing things done but in reality it may as well be impossible)
Cheers
Ryan
