Old 03-15-2011, 01:44 PM   #18 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Welcome Cliffy, Here is the link to Part C with the template you asked about.
http://ecomodder.com/forum/showthrea...rt-c-9287.html
Part A has photos of various cars under the template, IIRC. I have found the VW to be low clearance already. I put on an aluminum skid plate under the engine right after I got the car. My stock bumper cover scrapes sometimes so unless your roads are totally flat I might hesitate to spend much on a different bumper. I have gotten good results from cleaning up the underside with a belly pan from just behind the cat to the back bumper.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
