Old 03-18-2011, 10:18 AM   #74 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by dieseleverything View Post
Legit question here. Like what?
The easiest and cheapest solution is indeed to burn it ... so sadly that's what happens most often.
Though that can be done a lot more efficiently than in an old if not ancient car.
In Belgium :
87% gets processed into biodiesel - so it still gets burned inefficiently.
11% is burned to produce electricity and/or steam - the combination being the most efficient.
2% is being re-used in industrial lubes and soaps.
After processing, waste vegetable oil could even be re-used for the same purpose, but EU regulations forbid recycling for human food or feedstock applications.
We've had a bit of troubles with some greasy criminals mixing engine oils etc. into the feedstock.
