Old 03-18-2011, 08:04 PM   #23 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by bestclimb View Post
find the fuel injector relay under the dash to the left. It is a gray box as shown in the image. unplug the connector and then pull out the white wire holder in the back of the connector. A small flat head screwdriver applied to the ends where the white tabs show will free it. There is a black wire in the corner this is the ground, pull it out.
The electrical connection is made to the car under the dash at the far left side of the car a small gray box labeled PGM FI.
Originally Posted by 4mula View Post
Yes, the gray box/relay is beside the fuse box.
I'm sure having a hard time finding a gray box by the fuse box. Does the fuse box pull out? Maybe the 99 honda is different? There are a few plugs in the fuse box, and one outside of it but it's blue, and it's hard to read and get to the connections under there. Details and ideas are appreciated.
