if you post part numbers of the mosfets you have around the house i can draw up a quick schematic for you
and please confirm that the arduino outputs 0 to 5 v
also just noticed the diode disappeared off the coil of the solenoid for the ignition switch bridging solenoid, you will still want this one to avoid voltage spikes in your system.
