Old 03-19-2011, 08:45 PM   #7 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
60 LED 3W E27 White LED 110V 12000mcd $4.18
108 LED E27 3.8W White Corn Shape Light Bulb 110V-220V 5500K $5.29
White 60 LED 5 Watts Screw Base Light Bulbs E27 $9.49
Lot 2 E27 LED Spot Light Bulb 360Lm 6000K 3W $12.98
LEDs with a high luminous intensity typically have a narrow apex angle. Similarly, LEDs with a wide apex angle typically have a relatively low luminous intensity. The cause for this relation is ... LEDs of a specific class (for example, "high flux") all produce roughly the same amount of luminous energy. However, when a LED emits its total energy in a narrow angle, the intensity will be greater (in the direction of that angle) than when the same energy had been emitted over a wide angle.
candela (millicandela) to lumen conversion wizard
