I took off the glove compartment door, popped off the little side panel, and there's a gray box that looks like pgm-F1 and has the following information.
CME corporation
Relay Assy. Main
RZ - 0158
Mexico TEM 12v
Is this it? There's an orange colored plug in the bottom, that has 2 green, 2 yellow, 2 striped, and 1 black wire going into it. I popped off the plug but think that's not necessary to pull out the wire. Is there any way I can make sure this is the right wire, for example trying to start the car with it out?
Then I pull out the black wire (with pliers) and insert the wires for the k/switch, yes?
How can the k/switch be routed through the base of the shifter?
It looks like I could put a (2nd) safety switch right behind the top of the glove compartment door.
