Old 03-21-2011, 01:11 AM   #65 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Originally Posted by 2009Prius View Post
Was this graph recorded with both the engine and the transaxle heaters running from time 0:00? If so then does this mean that the engine heater heats up the engine much quicker than the transaxle heater does the transaxle? Thanks!
Yes. The engine heats up much faster partly because it has a much smaller mass than the transaxle. The coolant temp sender is also immersed in coolant in the engine whereas the MG1 and MG2 probes are in the windings so they would heat up slower and this would lag the coolant temp.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
