05-01-2008, 02:13 PM
#16 (permalink)
I meant outer circumference / diameter of the tire compared to stock.
If you're running tires with a larger circumference than stock, your odometer and speedometer will be under-registering. Which will reduce your apparent MPG calculations.
The width is another story! (Rolling resistance & aero penalties.)
