Old 03-22-2011, 03:25 PM   #1 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
2nd View of the Volt
I just got to see the Chevy Volt again this past weekend.
It was on display at the Milwaukee Hybrid Group meeting. The owner of the car is one of the first in the state of Wisconsin.
He gave a presentation about his real-world experiences with the car. It was great to get to talk to a real, live person, instead of GM marketing materials.
Of the fun odd little things to know about the car, it has a BUTTON to change the time on the clock. Yep, twice a year when you change the clock for daylight saving, you only have to hit one button, instead of a menu. However, there's already PLENTY of buttons on the center console. Is one more really needed that you only use twice a year?
He also mentioned how he missed the remote entry feature that he had on his Prius. On the Volt, you have the "old-fashioned" remote key fob, that you must pull out of your pocket and press.
In things that he LOVED about the Volt - Running on electricity - and electric torque! He also talked about all the neat little features in the Volt smartphone application. You can check your state of charge, turn the AC or heat on and off, an do a zillion other things right from your phone!
This car has a nice two-tone leather interior, including heated seats. Not only are heated seats comfortable, but they are a rather efficient way to heat the driver instead of the whole cabin.
He did mention that there were several times in the winter when the engine would kick on when below about 26 degrees Farenheight, even though the batteries were not low. He didn't know the technical reason why it happens, although I would guess that it may have to do with battery thermal management. Just as the Tesla has a huge radiator to cool it's batteries, perhaps the Volt uses engine coolant for battery temperature control?
It was also fun to see the Volt get plugged in. On the driver side, there is a charging port with a J1772 connection. To connect to a plain 15 amp 120V outlet, a special adapter cable is used, which conditions the power and takes care of the "handshake" data connection that's part of the J1772 spec.
Once the car is plugged in, a green LED lights up on the top of the dashboard (where it is easily seen from outside the car) and the horn makes a short, soft beep.
I did also notice that the production version of the Volt still doesn't have a simple cover over the six power cables going back and forth between the inverter and the electric motor. Somehow it just looks, I don't know... unfinished? It makes everything under the hood look just a little cluttered.
I also noticed that under the back, where the fuel tank is, it has a number of exposed wireharnesses. Not that most people go sticking their head under the back of the car all the time, but it did still have that feeling of maybe missing a cover or additional piece of trim.
Would I buy a Volt? Nah, it's out of my price range. I'd also have to weigh the electric only range vs other vehicles like the Leaf.
Would I drive one? You bet. It looks nice, accelerates great. It's a pretty cool car.
YouTube - Chevy Volt Walk-around
YouTube - Chevy Volt Charging
(Hmm - YouTube changed their style of embedding. Can anyone help me embed these two video clips instead of linking to them?)
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Last edited by bennelson; 03-22-2011 at 05:38 PM.. Reason: added videos, corrected spot where I said Prius when I meant Volt
