Old 03-23-2011, 03:40 PM   #208 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
TC Lock-Unlock Despite Switch
Hey All...
I took the Integra on a trip today and noted some odd behavior from the TC. Normally, when the TC Engagement Switch is closed, the TCU will allow partial, half, or full lockup depending on warmup conditions and throttle position. It has worked great for a long time...
Today, it started to kick in-and-out on the highway at speeds of 40-65 mph. At a TPS of 18 in D4, it would remain unlocked, where a solid TPS of 24 would mostly demand full lock (but not always). It used to lock after TPS-17 and hold (after warmup).
The only difference since last operation is warmer temperatures (in the 60's). I'm puzzled where to begin diagnosis -- the switch is functional and consistent. I'm thinking of resetting the ECU (battery disconnect) and if that doesn't work, tighten the throttle cable to the transmission. Hopefully the TC solenoids aren't failing (maybe a check of the fluid too). Any ideas???
Thanks...RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
