Old 03-23-2011, 06:24 PM   #62 (permalink)
mystere485
Barges Ahoy!
The Black Car - '93 Honda Civic Del Sol si
90 day: 33.68 mpg (US)
The Benz - '70 Mercedes-Benz 220d
90 day: 33.13 mpg (US)
acura - '98 acura EL Premium
90 day: 29.91 mpg (US)
Send a message via AIM to mystere485
Originally Posted by mcrews View Post
If you are going to go alot of hyway driving, go one size up on the tire (NOT THE RIM)
FOR EXAMPLE 245/45/18 would be 255/45/18 or an increase in the diameter of 3.4%. Or about 1/2 inch taller.
And If you really have read the tire threads, you would see that a taller tire (up to a limit) is actually HIGHLY recommended.
I will be in the boat for new tires, the vic currently has I believe 215/60/15(don't quote me) on right now. So the suggestion would be to go to a 215/65/15 or possibly a 215/70/15? would changing the width to a 205 or a 195 make a difference?
As a side note, would lowering the car offset the height difference?(edit:duh, what i meant to ask was; would the combination of lowering the car an inch in combination with increasing the tire diameter prove favorable mpg wise?) the car has plenty ground clearance and could afford to hug the road a little more.
