Old 03-24-2011, 02:05 AM   #52 (permalink)
AeroModder
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
That's actually the test order. The first run was at about 10:30 AM, so it was warming up a little by the time I tested the stock configuration at the end. There was about 20-25 minutes between runs, since I had to remove pieces and drive back out to the highway, then turn around so I'm going the same direction each trial.
I should have taken three videos of each, but I was using the same locations as the mudflap runs.
In Reason we Trust
