Originally Posted by zonker
if you want to add a little height to the tire, you can easily run a 185/70-14, and this would drop your engine rpms at any given speed by 3%. This also means that when your speedo reads 60mph, you're doing almost 63mph.
This size change also changes the accuracy of the odometer reading, no?
