EOC and restarting enrichment. Is there a workaround?
When restarting after an EOC most cars enrich the mixture for several seconds at least, correct? So if you have a kill switch and wire in a separate starter button does the ECU still detect the restart and enrich or does it fool the ECU?
I'm trying to optimize my P&G but I think the automatic enrichment may be hindering my results.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
