Thanks roflwaffle. That's perfect. BTW, What's the waffle in roflwaffle?
Originally Posted by Daox
I know my 97 Paseo sends a signal to the ECU when the engine is being started.
I wonder... if you start the engine with a switch direct to the starter solenoid does that still cause the signal to be sent?
Glad to see you back on the board orange4boy.
Thanks for the welcome back. I managed to crawl out from under my rock.
![Wink](/forum/images/smilies/wink.gif)
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
