Old 03-26-2011, 10:34 AM   #11 (permalink)
Sularus
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
vtec-e - the same seafoam you use in a gasonline engine is the one to use in a diesel engine. It is safe for both. You would have to pick up a can and read the directions, but from what I recall, it is the same procedure for both. Suck in some through the brake booster hose( or any vacuum source), shut off engine and let sit for about 20 min, then start and run until no more smoke. Sometimes a second application is needed. If a vehicle has never been cleaned with it I usually will use a 1/2 can in the intake, and a full can in the tank. After I use all of that tank I will get some Lucas upper cylinder lube and put it into the second tank. Works wonders.
J
