Originally Posted by Christ
Last tank was 48.1mpg, all ULSD. Just changed the sooty oil out for clean 15w40 diesel oil (Delvac), and will likely swap to 0w20 after a good run of this.
Currently working on getting spherical strut bearings made.
I would advise against 0w20 because it would probably start leaking like mad and using a lot of oil because it would be so thin to easily pass through the piston rings, people have also reported starting problems with lower viscosity oils.
They are made for 15W40, maybe 10w40 but not on a high miler. I had one of these Golf II diesels for my first car
![Smile](/forum/images/smilies/smile.gif)
