A bad O2 sensor can cause high FE and your car is due at 135000km. The fact that the O2 sensor heater is gone is a warning sign that the sensor may be malfunctioning too. Already, without the heater it will put you car in open loop for longer than normal: uses more fuel.
An O2 sensor can be bad and not through a code. Mine was working in reverse a
while back and caused all kinds of strange behaviour including poor mileage so that would be my first suggestion: replace O2 sensors. You can get $ generic ones installed. don't need to get $$$ dealer parts.
The O2 sensors are bolted to your exhaust pipes in front of and behind the catalytic converter. Do em both.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
