Thread: Mk2 Prius
Old 03-30-2011, 09:08 PM   #8 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Hi,
With that many miles, the tires are probably OK but you may want to shop early for low, rolling resistance tires. Now my understanding is the EU practice is to avoid tire rotation so front tires wear out first and are replaced in pairs while the rear tires wear out on a longer schedule. Credible USA sources for tire rolling resistance is poor and I know even less about EU sources on tire rolling resistance.
You may want to consider an engine block heater. When temperatures fall below the 3-5 C range, a block heater can materially improve mileage. Some folks advocate year round block heater usage to handle the universal, cold-start, fuel burn.
BTW, I'm under the impression the EU, NHW20s (your model) do not have a coolant thermos to accelerate ICE warm-up. However, Ken@Japan shared some warm-up data and it has an advanced warm-up profile. Still, the car responds best if lower power is used in the first mile or so during the ICE warm-up.
If the car does not have an EV button, there are many hacks to add one. However, EV mode has marginal use ... primarily to move the car around a parking lot ... and scare the horses. <grins>
Instrumentation helps and I find ICE rpm and coolant temperature to be the two most useful. Coolant temperature because until it reaches 70C, the ICE tend to burn more fuel to improve warm-up. ICE rpm needs to stay under 2,200-2,600 rpm to stay in the high efficiency regions. Higher rpms are not bad but rather ... less good.
GOOD LUCK!
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
