Old 03-31-2011, 09:59 PM   #23 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Issue resolved.
Cause: faulty 4-pin computer connector that I put in, to give a way to unplug the Guino. Not the tiny ones for floppy drive, the larger ones that powered hard drives and plenty other stuff 'till the SATA drives came out.
I never could determine for certain if it was the male or female connector, or was it the pin/tube fit or the crimping of the wire to the connector contact. But I did determine the +12V wire passing thru the connector was intermittent.
Cure:
Severed the wires on either side of the connector. Inserted 8-10" of new wire in line. Twisted bared leads, soldered, then covered with heat shrink tubing and shrunk it. Seems to be fine now. I hope I didn't jinx it by saying so.
I got the cap and diode from Radio Shack but didn't bother putting them in. I think I'll return them. This fixit job was enough of a PITA as it was, without opening up the project box that holds the existing 8 Ohm resistor and redoing all that. It was worth it though.
Coast long and prosper.
