Thread: rubbing noise
Old 05-02-2008, 01:35 PM   #19 (permalink)
Daox
It does seem to take a good turn to make it much louder, especially at low speeds. At higher speeds it doesn't take as much of a hard turn to get noise. This makes sense since the noise is proportional to the load on the bearing. It does not pull one side at all. I haven't checked the heat shields. I'll definitly check that out. I'll try the tire thing too before tearing the hub apart. Thanks for the info.
