Old 05-01-2008, 06:51 AM   #11 (permalink)
Yeah, the bearing was kind of what I was thinking... I'll have to wait until the weekend to take it apart again though.
Old 05-01-2008, 06:22 PM   #12 (permalink)
Well, I jacked the car up tonight to see if there was any plan or noise just rotating the wheels by hand. The passenger side one rotated freely, slight brake noise which I'm assuming is normal, and there wasn't any play in it. The driver's side was the same except that it didn't roll quite as freely. Still no noise from either with them jacked in the air.
I didn't take the tires off, but I know the suspension parts were all tight as I looked at that while I was doing the brake job. Theres nothing protruding out that would rub either.
Also, to clarify, I do get noise just going straight. The noise increases with speed and also when I turn to the right.
Old 05-01-2008, 07:33 PM   #13 (permalink)
Just got back from a ride with the wife driving. Its definitly the front passenger side. Slow movement (coasting down the driveway) you can hear it a little, but its once you get up to 20-30 that it really gets loud.
Old 05-01-2008, 09:33 PM   #14 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
does it sound like rubbing of tires on plastic? metal on metal? I'm trying to get the sound in my head.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-02-2008, 01:20 AM   #15 (permalink)
90 day: 49.35 mpg (US)
Wheel bearings that are going sometimes get described as a grumbling or a propeller sound. Suggests a lower tone.
Old 05-02-2008, 01:27 AM   #16 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
jack the front end up again. Leave the tires on, and wiggle the tires back and forth. put your hands at 12 and 6 o'clock position, and give it a shake, that's what mechanics do to check for play. if it moves more then a hair, there is play. Then move your hands to 3 and 9 o'clock, if there some play, then it's usually tie rods.
If you don't see or feel where it is rubbing inside the wheel well, then chances are for wheel bearings.
Randy
Old 05-02-2008, 08:13 AM   #17 (permalink)
Thats exactly what I did Meemooer. There wasn't any noticable play in it. I also checked the steering linkage and drive shaft. Everything was tight. Annoying stuff I tell ya!
The noise sounds like metal on metal, but not really as harsh. Its definitly not a hum. Its almost as if your brakes are down to metal on metal, but its not as loud as that. It is constant (doesn't pulse) and increase in volume as speed increases and during right turns.
I'm still thinking its probably a bearing. I'll have to get my dial indicator out this weekend and measure the runout of the hub.
Old 05-02-2008, 12:20 PM   #18 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I think it has been said, but check the Heat sheild on the inside of the brake rotor.
Wheel bearings TYPICALLY get much worse when in HARD turns. I've heard them described as a washing machine full of marbles, but they sound more like bad bearings to me.
Does it pull to one side or another?
Sometimes noises get transmitted through the car in all sorts of WEIRD ways. For example one time I could have SWORN that a rear end was shot, but come to find out it was a roof rack.
Don't rule out your tires either, sometimes the best way to check that is to swap front to back.
Good luck!
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-02-2008, 12:35 PM   #19 (permalink)
It does seem to take a good turn to make it much louder, especially at low speeds. At higher speeds it doesn't take as much of a hard turn to get noise. This makes sense since the noise is proportional to the load on the bearing. It does not pull one side at all. I haven't checked the heat shields. I'll definitly check that out. I'll try the tire thing too before tearing the hub apart. Thanks for the info.
Old 05-02-2008, 06:14 PM   #20 (permalink)
I know that the 608 bearings on my skateboard would make a metal-on-metal sound from lack of lubrication or just dirty lubrication. have you tried cleaning and re-greasing the bearing?
Car making a scary noise jesse.rizzo Off-Topic Tech 5 04-12-2008 02:50 PM
News: Maryland legislators may require cars to make some noise MetroMPG Fossil Fuel Free 9 02-22-2008 08:51 AM
