Old 04-01-2011, 10:39 AM   #31 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by jkostec View Post
Adam,
Nice work on the PCB. I used to be in the electronics fab industry. If you are going to assemble these for people and the numbers justify it, you may want to consider ordering a stencil and using solder paste. Even hand soldering becomes much easier. I've ordered 100s, so if you wanted help let me know.
Thanks again for the good work,
John K.
Im actually doing that now! lol. I have a friend with a cnc vinyl cutter that I use to make my own stencils out of mylar film. Its great and free. Then pop it into the taster oven in the garage to melt the solder and done with the smd stuff.
If there is enough interest, I will have my friend with the pick and place machines build them in runs.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
