Old 04-04-2011, 11:35 PM   #126 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
Originally Posted by Christ View Post
So the only time the electric motor will be able to do anything is with the engine spinning?
Right, the motor has a solid direct connection to the engine crankshaft, so if the motor rpm == engine rpm.
It's not a bad idea, but is there no way you could get it between the engine and transmission, with the clutch between the gasser and e motor?
This would allow electric only drive, simply by pressing the clutch pedal, but still allow the e motor to s start the engine, provide power assistance, and charge the battery while driving.
The real key as I mentioned, is this adds no weight over a traditional gas engine drivetrain, yet could improve mpg. I'll be using a lithium battery pack, that will weigh about the same as a lead-acid starter battery, maybe a little bigger, we'll have to see.
It would take a much bigger motor and probably hundreds of lbs of batteries to power the car any distance without using the gas engine.
