Originally Posted by NashvilleEVFiero
Thanks for putting this together.
Just a couple of tard questions. How many amps is the driver good for? I have the P&S boards. This replaces the standard drivers for more amps with the DC open revolt? If am interested in 2 boards if it will handle at least 1000 amps.
That would depend on your IGBT's. The VLA500-01 drivers are good for up to 1400A IGBT devices, so with 2 VLA's, you could put down 2800A as the
theoretical limit of the controller.
I'd say a safer bet would be along the lines of 2000A or so.
