Originally Posted by gabi
well.... i checked the fuse ,and is rated 20 amps
im realy confused, the manual says tipical load at 60 amps, but the fuse is 20 amps,... that makes no sense to me
You're looking at the fuse that's for the field control in the alternator what essentially dictates the output of the alternator going to the battery through another fuse which is a fusible link. Looks like a section of wiring but designed to melt/open the circuit when overloaded. I don't know it's rating.
