You could still start the gas engine using the electric motor no matter whee it is in relation to the test of the parts. If it's behind the clutch, you just start the engine by moving the vehicle. Not entirely bad, anyway, as the setup would then alleviate any need for the gas engine to idle. Of course, you could still have this feature as is, simply by not pushing the clutch when you activate the motor.
