Originally Posted by roflwaffle
In this case I think the problem is that after aeromods a 4.6L engine running at ~1500rpm will still be in a crummy portion of the BSFC map (~350+g/kWh). In order to get into a nicer portion taller gearing (~1000rpm@60mph) or a smaller engine would probably be required.
Fuel consumption goes to zero when the engine is off. 40mpg will require hypermiling, and that's tough with an auto. There's no way he'll get there without a manual tranny.
The
TR-3650 came in Mustang GTs and has as high as a 0.62:1 OD. That would help and should have the same bolt pattern as the 4.6L in that Crown Vic.
