Old 04-06-2011, 08:27 AM   #18 (permalink)
3dplane
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Originally Posted by Ryland View Post
Yes, it would cut power from your alternator.
Fuse block for the alternator is going to be between the alternator and the battery, fallow the large cable from the alternator to the battery.
Sorry but there is no fuse block between the alternator output (large cable)and battery.
The battery + cable splits in two.One goes to the alternator and the other to the starter. Each of these have a short section of wire called either fuse link or fusable link designed to work like a fuse if the respective component shorts and tries to put B+ to ground.
