You've replaced the ball joint, upper and lower, the tire rod ends inner and outer, and the hub/bearing assembly, and it's still got play in it?
The options that are left are the strut assembly, and various bushings which could be excessively worn.
If I get a chance to make it to GGP, and you're there, maybe I can take a feel and see if I can identify it for you.
