Old 04-06-2011, 02:45 PM   #166 (permalink)
jackbauer
jackbauer's Avatar
Bit of a weird one today. Looks like i have taken out the rs232 transciever. I swapped out the micro for one with the modded software with the fuel driver bug removed. Adjusted pot with no results so looks like reverse pwm may be required. Then when i went to test the unit was not displaying data from the controller. Checked with a laptop and controller all ok. Connections ok , so its most likely the transciever. I'll swap it out tomorrow and report back.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
