Old 04-03-2011, 10:42 AM   #161 (permalink)
EV Builder
Freyguy's Avatar
Originally Posted by apowers View Post
I got my LCD mounted in the dash today. It is working now. Thank You Chris.
It seems like it was an "ancient version of firmware in the controller". Thank You Adam. Her are some pics.
Alvin,
A little bit of customization I see. Display of "Tbat" is now "Tcab". You just connect the thermistor directly onto terminal block TB1 or have it in another location in the cabin?
Old 04-03-2011, 05:55 PM   #162 (permalink)
EV Builder
Freyguy's Avatar
Latest Firmware version 1.2 and revised BOM
OK gentlemen, I addressed the issues identified thusfar and would like to call this my final contribution. I updated the BOM to show note2 this time (R20 selection) and changed J1 header to a 2-pin terminal block like jackbauer used. Also indicate 411systems as alternate source for LCD.
Firmware changes as follows:
- Oversampling for 11-bit resolution on pack and accessory voltages. This doubles the resolution of these voltages, but is really not 11bit. I'd call it 10-1/2 for accuracy
- Implement 3x transmit of profile parameter values to ensure accepting. I had tried disabling controller with rtd-period=0 first, but even having it accept this was hit or miss! It seems the brute force method works best- just retransmit profile 2 more times and it took all parameters every time!
- Fix fuel gage PWM bug (remove the rogue line of code).
- Extend MTE/KTE display to 3 digits
For this firmware update I only included the ASM files (a for PIC18F2420 and b for PIC18F2480). Just replace the existing 1.1 ASM files in the project with these and recompile.
Hopefully sawickm can get these up on the portal.
It was really cool seeing jackbauer and apowers versions installed & working. I have ideas for tracking charge current, reading a speed sensor and even monitoring and displaying brake vacuum using a freescale MPXV6115VC6U (latter two require the PIC18F2420). If I get them working I will certainly post them along with code. They'll probably be summer projects.
I'm sure others will do the same.
Good luck everyone
File Type: zip Cougar LCD Instrumentation Board BOM_4-02-11.zip (43.3 KB, 51 views)
The Following 5 Users Say Thank You to Freyguy For This Useful Post:
1-ev.com (04-26-2011), apowers (04-03-2011), jackbauer (04-03-2011), mrbigh (04-03-2011), pnikolaj (04-03-2011)
Old 04-04-2011, 03:15 AM   #163 (permalink)
VW Polo EV
More LCD Display PCBs coming
To anyone that missed out on getting one of the last batch of boards.
I am getting a new batch made & I expect that they will arrive in about 2 weeks.
These ones should have the top & bottom silk screen layers printed OK.
PM me if you are interested in getting one (or more).
Old 04-04-2011, 04:04 AM   #164 (permalink)
PCB board
I am in for one.
Old 04-04-2011, 01:16 PM   #165 (permalink)
ReVolt Enthusiast
Hi Chris,
I'll update the wiki tomorrow with those new files.
-Mark
The Following User Says Thank You to sawickm For This Useful Post:
Freyguy (04-05-2011)
Old 04-06-2011, 03:45 PM   #166 (permalink)
jackbauer's Avatar
Bit of a weird one today. Looks like i have taken out the rs232 transciever. I swapped out the micro for one with the modded software with the fuel driver bug removed. Adjusted pot with no results so looks like reverse pwm may be required. Then when i went to test the unit was not displaying data from the controller. Checked with a laptop and controller all ok. Connections ok , so its most likely the transciever. I'll swap it out tomorrow and report back.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 04-08-2011, 03:11 PM   #167 (permalink)
jackbauer's Avatar
Quick update. Back up and running today. Looking increasingly like R32 (1k) in the rs232 circuit was either faulty or i screwed up the soldering.
www.evbmw.com
Old 04-19-2011, 04:02 AM   #168 (permalink)
VW Polo EV
New batch of COUGAR Instrumentation LCD pcbs have arrived
The boards have arrived & they look 100% including the component silk screen & the underside silk screen.
Cost includes padded bag & postage worldwide by regular air mail.
AU$20 for 1 pcb
AU$35 for 2 pcbs
Payment can be made via my paypal account.
ianbartie@hotmail.com
Registered post and insurance can be done at extra cost.
Click on the picture for an enlarged view.
Old 04-19-2011, 12:30 PM   #169 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
[QUOTE=ianbartie;232524]
QUOTE]
Nice, I wish I had the silkscreen before my build.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 04-19-2011, 06:07 PM   #170 (permalink)
AU$20 for 1 pcb
AU$35 for 2 pcbs
Good one Ian. Sorry your original board went astray in the mail, but the up side is you wouldn't have done it if it hadn't!
Sometimes I sits and thinks and sometimes I just sits.
