Old 04-07-2011, 07:57 AM   #31 (permalink)
racprops
The ones I have were made to be used and came with the Zemco MPG Computer.
It uses a light bulb and a photocell, the light is blocked by a small ballbaring running though a grove pushed by the fuel flow.
It is well made and has withstood the fuel pressure on my Chevy Van.
The output is a short, as the instructions say to test by tapping the wires together.
It takes a couple of tanks of gas to refine the calaberation, and it can be updated easly.
I plan on updating the system with a LED and light reading LED.
Both the photocell and light was subject to failure.
The computer is again the Zemco MPG Computer, or perhaps your MPGunio...
The Zemco uses a low rate pulse and I understand it will be slower than the MPGunio.
As I think about it: the flow rate of a fuel injector system maybe higher that the old carb systems, so a system to divide by 2, 4, 6 might be needed to slow down the pulse rate output to the Zemco MPG Computer.
Rich
