Old 04-07-2011, 07:57 AM   #31 (permalink)
The ones I have were made to be used and came with the Zemco MPG Computer.
It uses a light bulb and a photocell, the light is blocked by a small ballbaring running though a grove pushed by the fuel flow.
It is well made and has withstood the fuel pressure on my Chevy Van.
The output is a short, as the instructions say to test by tapping the wires together.
It takes a couple of tanks of gas to refine the calaberation, and it can be updated easly.
I plan on updating the system with a LED and light reading LED.
Both the photocell and light was subject to failure.
The computer is again the Zemco MPG Computer, or perhaps your MPGunio...
The Zemco uses a low rate pulse and I understand it will be slower than the MPGunio.
As I think about it: the flow rate of a fuel injector system maybe higher that the old carb systems, so a system to divide by 2, 4, 6 might be needed to slow down the pulse rate output to the Zemco MPG Computer.
Rich
Old 04-07-2011, 08:25 AM   #32 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by racprops View Post
Both the photocell and light was subject to failure...
Ah, I think the ball is also subject to melting.
DieselJohn was entertaining building something similar. IF the sensor were something that other folks could reliably obtain cost effectively and were accurate, I would consider customizing a guino to track single or multiple pulse signals (i.e. with differences).
Old 04-07-2011, 08:40 AM   #33 (permalink)
Well out of four meters, I have not seen a melted ball...
So I guess I wait for Dieseljohn's work.
Rich
Old 04-07-2011, 08:42 AM   #34 (permalink)
dcb
needs more cowbell
dcb's Avatar
or get some help converting your device to negative switching, since that should be a trivial change.
