Old 04-08-2011, 04:01 PM   #268 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Check t that axle if theres thumping going on. Just changed both axles on my wifes saturn to fix some major thump/wobble.
Cutting out while cornering used to happen to my Topaz. It turned out to be a bad fuel sending unit/pump assembly. I've got another fuel pump you can have that worked fine when I pulled it, if you want. Suppose I can ship it if you want to cover that.
The Following User Says Thank You to Christ For This Useful Post:
Wonderboy (04-09-2011)
