The Quad 4 / Dual Cam 2.4 was a POS! Every one I've unfortunately owned gave me problems. PRAY that your water pump never goes out on one. Why is that? Because it's driven by the timing chain! Not easy to get to or fix once you're in there! The coil housing plastic would crack over time causing a short. Bad design and a nightmare to work on.
VT247
Originally Posted by 88FieroGT
and back then they didnt even use the quad 4 which was more efficient and had more power.
