Old 04-09-2011, 04:17 AM   #269 (permalink)
DamageX
Hi Will, how much fuel was in your tank at the time? In my 320i it is possible to starve the fuel pickup and stall the engine during a hard right-hand turn if the fuel level is down to 1/4 or less.
Cars with fuel injection circulate more fuel than the engine ever needs, and pressure at the injector(s) is controlled by a spring-loaded regulator.
(There are exceptions... like diesels, direct injection, etc.) So usually you can use any random fuel pump as long as it is meant for fuel injection. It`s either enough or it isn`t. Also, when the engine is off, the system should still hold pressure to prevent vapor lock and whatnot. Losing pressure could cause hard starts, and it could be a fault with the pump, injector(s), or regulator (or a leaky connection).
As you know, I`m not an expert on the Metro, but I`m pretty sure this info is relevant...
The Following User Says Thank You to DamageX For This Useful Post:
Wonderboy (04-09-2011)
