Thread: Noob.
Old 04-10-2011, 02:44 AM   #3 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Camgirl,
Welcome!
If you have tires coming due, think about increasing the diameter a bit. THis will lower the final rpm when cruising thus give you better mpg.
For example: I run 255/45/18 on stock rims. The fctory size was 245. both tires weigh the same so It was a net gain by lowering the final rpm. I am on the road so every litlle bit helps.
Have to get a scangauge or some sfter market device that keeps you focused on mpg. Really makes a difference. My car has a factory mpg screen and i would useit. But having hte scangauge takes it to the next level.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
