Old 04-10-2011, 01:52 PM   #10 (permalink)
sallen
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Right... Finally got the bugger on!
I built some brackets and bolted them to the tray, then bolted all three panels under the car. I mostly used existing bolts for the exhaust etc to attach the brackets to.
At the rear I spaced the rear edge of the tray down from the bumper using long bolts and bits of copper pipe.
Because the tray covers the rear silencer (with a hole cut out for the exhaust pipe tip) I built a heat shield with a hammer, out of some scrap aluminum I had lying about. It separates the plasic from the silencer.
I've tested it to motorway speeds and nothing has fallen off yet...
Looking forward to results.
ID:	8101   Click image for larger version
ID:	8102   Click image for larger version
ID:	8103   Click image for larger version
ID:	8104   Click image for larger version
ID:	8106   Click image for larger version
ID:	8107   Click image for larger version
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
