Old 04-12-2011, 03:24 PM   #15 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Bill in Houston View Post
Did you do anything to protect it from the heat of the exhaust?
The coroplast is in direct contact with the exhaust pipe in a couple of spots and it hasn't been a problem. The catalytic converter is open to the air but diesel exhaust is much cooler than gas cars.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
