Old 04-13-2011, 12:12 AM   #6 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by ngrimm View Post
Thank you. I think I'll give it a try. The underside of this Bronco looks pretty "unclean" to me due to the ifs(diffs?). The front differential is nearly a flat surface hanging down 12" below the frame. At least the old straight axle 4x4's had a rounded housing. Would having a belly pan that starts at the existing bumper/spoiler and angles down to cover the axle work instead of adding an air dam? I've been reading all I can on this forum for about a year but don't recall seeing that discussed.
If you are suggesting using the bedliner from below the bumper angled downward, it sounds like a better design for an off-road skid plate than for improving aerodynamics. Big Dave on this site has had good success with a big air dam on a full size truck. I really do like the idea of repurposing a discarded bedliner as belly pan material. Could you try an airdam and a lowered belly pan below the differentials like BamZipPow's Toyota?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
