Thread: I give up.
Old 04-13-2011, 11:55 AM   #26 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by Ryland View Post
If you end up getting a VW I think you are going to find the same thing as you found with your hybrid, mechanics who don't want to work on it or who do then screw things up, at least judging from the VW's I have owned and worked on and the friends who have VW's who have to call around to all the shops to find someone who is willing to buy the special tools that only VW uses.
This is absolutely correct. VW TDIs are excellent cars, but the problem with these is you CANNOT use the dealer for service. VW dealers are notorious for over-filling and using the wrong oil, for not using the proper tools or parts to replace timing belts, for causing more damage and covering it up. The new CR TDIs have $4000-$10,000 bills if the dealer or factory determines you used bad fuel, and I suspect they are covering up for a poorly manufactured or designed fuel system.
Eyes open.
I'm not coasting, I'm shifting slowly.
