Old 05-03-2008, 01:11 PM   #1 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Unhappy HELP: Any HVAC Experts?
I have a bit of a problem...
My heat-pump compressor won't activate (it's temperate enough this weekend to open the windows, but a test of the system revealed some trouble).
Symptoms:
  • A/C will not engage; thermostat does not indicate operation at setpoint
  • Heat will not engage, but thermostat indicates that it is running
  • Aux-Heat (Gas) functions properly
  • System blower fan is functional
What I've checked:
  • Power to the compressor
  • All wiring is intact at the 'Stat, Furnace/Blower, and Compressor
  • Circuit breakers OK
  • System status LED at furnace/blower indicates "Normal"
  • No trouble codes at the 'Stat
  • Outdoor temp is functional from the 'Stat display
We've had some pretty bad storms with lots of lightning lately. We usually either get struck nearby, or take a surge from a strike. My guess is a bad relay somewhere, which is beyond my repair.
Any thoughts? Someone will have to come out Monday if I can get it fixed.
Thanks...
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
