The final intent of this project is to make an LED dimmer that can handle 6 watts.
It just so happens that a motor controller design will work just fine for the project.
The next step would be to have the output drive a transistor instead of an LED.
The transistor will handle the higher power and do the actual switching.
If I were building a full-scale EV motor controller from scratch, I would just go with the Open Revolt design.
This little project is as much to learn about electronics as anything.
