Originally Posted by UFO
This HHO thread is reminding me of a fellow I worked for 10 years ago. He was designing switching power supplies, and his goal was over-unity. He had a machine that would measure the power out/power in of the supply, and by inducing a load transient, it would momentarily calculate efficiency greater than 100% (due to phase lag), he thought he could make a supply that would create power from nothing.
FYI you can get power from basically nothing. you can put a antenna about 40feet or higher in the sky, put a copper pole 3 feet deep in the ground and connect them to a transformer and get a constant volt.
its what Tesla was doing. using the volt in the sky and amplifying it to gain high voltage, current ect...
